Kapro108 Plumbing Installation Level 710mm (28")
113473
From £39.62 £33.02
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery tomorrow, Friday 11th Jul
  • Online exclusive
  • Precision 28inch plumbing installation level
  • Features two solid acrylic shockproof vials
  • Vertical vial with Kapro's patented plumb side dual view
  • Allows for easy and accurate readings
  • Horizontal vial with gradient lines up to 2%
  • Markers at standard sink installation points
  • Shock-absorbing rubber end caps
  • Wall grip feature allows for one-handed use without scratching or damaging the wall
The Kapro 108 Plumbing Installation Level is a 28 inch long precision tool designed to simplify plumbing installations with ease and accuracy. Manufactured with two solid acrylic shockproof vials, this level ensures durability and reliable performance in various conditions.
The level features a vertical vial with Kapro's patented plumb side dual view, allowing for direct viewing of the vertical vial without the need to twist or bend your neck. This design ensures easy and accurate readings every time. The horizontal vial includes gradient lines up to 2%, providing precise measurements for various applications.
It is equipped with markers on the profile at standard sink installation points: 280mm for sink attachment to the wall, 150mm for tap placement, and 75mm for water pipes below the sink. These markers simplify the installation process, ensuring accuracy and efficiency. The shock-absorbing rubber end caps on either end protect the level from damage if dropped, enhancing its durability.
Kapro's wall grip feature allows you to keep the level against a flat surface with one hand, preventing scratches or damage to the wall. This feature adds convenience and ease of use, making the Kapro 108 Plumbing Installation Level a reliable tool for any plumbing task.
