Karcher K 3 Home Pressure Washer 120 bar 230V
113050
From £176.98 £147.48
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 15th Jul
  • Online exclusive
  • Adjustable pressure, simply twist to the ideal setting
  • For stubborn dirt, use the Dirt Blaster lance
  • The Power Control Vario lance allows you to adjust the pressure as you work
  • Effortlessly apply detergent, enhancing your cleaning performance
  • Telescopic handle and two smooth-running wheels for easy movement
  • Store cable, 7m high-pressure hose, and accessories when not in use
  • Kärcher App provides everything you need from setting up your machine
  • Tailor the app to your machine and accessories for the perfect cleaning result, step-by-step application guides
  • Comes complete with a 2-year warranty for peace of mind
The Kärcher K 3 Power Control Car & Home Pressure Washer is the ultimate solution for tackling the toughest cleaning tasks with ease. This versatile pressure washer is designed to make your cleaning routine more efficient and effective, whether you're sprucing up your patio or giving your car a perfect shine. With the Kärcher K 3 Power Control Car & Home Pressure Washer, you can achieve professional-level cleaning results effortlessly. Whether you're cleaning your patio, driveway, or car, this powerful and versatile tool has you covered.
The Home Kit includes a patio cleaner and detergent to efficiently clean your outdoor spaces. The Car Kit comes with everything you need to give your car a perfect shine.
Supplied with: 1 x Vario Power Spray Lance, 1 x Dirt Blaster Lance, 1 x High-Pressure Gun, 1 x 7m High-Pressure Hose, 1 x Car Wash Brush, 1 x Foam Nozzle, 1 x T 150 Patio Cleaner, 1 x 500ml Patio & Deck Detergent, 1 x 3-in-1 Car Shampoo.
Max. Pressure: 120 bar
Flow Rate: 380 L/hr.
Max. Water Feed Temperature: 40°C
Hose Length: 7m
Weight: 4.4kg (machine), 7.8kg (with accessories)
