Karcher T5 T-Racer Surface Cleaner
- Online exclusive
- Capable of removing dirt from large outdoor areas quickly and effectively
- Cleans in around half the time compared to a spray lance
- Adjustable nozzle can be repositioned depending on the surface
- Suitable for both hard surfaces as well as delicate surfaces like wood
- Protective hood shields against spray water
- Hovercraft effect amplifies manoeuvrings
- Makes the cleaning process smoother and more efficient
- Ergonomic handle allows for easy cleaning of vertical surfaces
- Suitable for pressure washer ranges K2-K7
Introducing the Kärcher T5 T-Racer Surface Cleaner – the ultimate solution for efficient and versatile outdoor cleaning. Designed to tackle large areas with ease, this surface cleaner offers a range of features that make it a must-have for any cleaning task. Suitable for pressure washer ranges K2-K7.
With the Kärcher T5 T-Racer Surface Cleaner, you can achieve professional-level cleaning results in less time and with less effort. Whether you're tackling tough grime on concrete or gently cleaning wooden surfaces, this versatile tool has you covered.
EAN Barcode | 4054278513652 |
Model | T5 |
- Standard Delivery* - Free
*UK Mainland only. Order before 3pm for Next Day Delivery. Additional charges may apply for remote or offshore areas.
