Axminster KJD12 NVR Switch 230V 1ph c/w Box
- Simple no volt release switch - controls power on or off
- Supplied with mounting box and two cable glands
- Capable of switching up to Max 2,000W with no volt release protection
- Push on terminals
- 80 x 115 x 60mm deep
- Four fixing holes on 45 x 75mm centres
A no-volt-release switch complete with mounting box and two cable glands capable of switching induction motors up to 750W and brush motors up to 2,000W with no-volt-release protection (not overload protected). Due to the build of this switch it is not suitable for use with additional safety switches and can only be used to control the power simply on or off. The switch uses push on terminals, with mains supply in on terminals 1 and 3 and power out on terminals 2 and 4. Size 80 x 115 x 60mm deep with four fixing holes on 45 x 75mm centres.
| EAN Barcode | 5052511025183 |
- Standard Delivery* - £5
