Kirschen 1101 6 Piece Bevel Edge Chisel Set
- Quality German chisels supplied in wooden presentation case
- Well-shaped white beech handles with steel ferrule
- Fully polished high carbon steel blades, 6, 10, 12, 16, 20 and 26mm
Available as a set of six chisels in a wooden presentation case. The Kirschen 1101 chisels are a fine example of a time when chisel makers took care to ensure that the handle was matched to the blade width. In this case the six chisels are fitted with gradually larger white beech handles. From the 6mm to the 26mm blade, each well-shaped handle is fitted with a steel ferrule. The blades are fully polished front and back and produced from Kirschen's own high carbon steel. The set comprises 6, 10, 12, 16, 20 and 26mm widths in a wooden case.
EAN Barcode | 4016649110655 |
Model | 1101 |
- Standard Delivery* - Free
