Laguna 18|36 Woodturning Lathe 230V
- Bowl turning capacity of 450mm diameter over the bed
- Heavy cast-iron bed ensures maximum stability and minimal vibration
- Self-ejecting tailstock with long quill travel extends reach and usability
- Forward and reverse rotation enhances versatility and finish quality
- Indexing positions at 14, 36, and 48 for precise and repeatable patterns
- 1.5kW induction motor with a VFD frequency converter
- Digital speed readout allows for precise control and monitoring of speed
The Laguna 18|36 Woodturning Lathe is designed with the user in mind to prioritise strength, stability, and control, satisfying both specialists and woodturning professionals. Its robust construction, advanced features and user-friendly design make it an indispensable asset in any workshop. This lathe features a bowl turning capacity of 450mm diameter over the bed and a swing over banjo of 340mm, making it versatile for a wide range of tasks.
The solid bed, with an impressive width of 208mm, is made of high-quality ASTM A36 steel, which is tougher than cast iron. This precisely ground bed ensures smooth travel of the headstock, tailstock, and tool rest, providing stability and reducing vibrations. The headstock, tailstock, and legs are made from heavy cast iron, securing minimum vibration and high comfort for turning oversized pieces.
One of the striking features of the lathe is an ergonomic panel with controls mounted in an anodized aluminium plate. The speed is smoothly controlled with a tactile rubber augmented knurled aluminium dial, and the blue hue of the speed indicator makes this machine stand out from the competition. The easy access rubber grip lever for belt change simplifies and speeds up belt adjustments, while the self-ejecting tailstock, with long quill travel of 114mm, enhances convenience and efficiency during operations. Tailstock and headstock cam lock levers are placed on the back of the machine to avoid interference, and all cam lock levers have soft grip handles and a long length, resulting in a firm feel with no deflection.
The variable speed feature is ideal for delicate work, large diameters, or unbalanced pieces, giving you the control you need for any project. The lathe offers forward and reverse rotation, providing versatility for different turning tasks. The indexing positions at 14, 36, and 48 allow for precise and repeatable positioning. The spring-loaded spindle lock facilitates quick and secure spindle changes, and the hardened steel leading edge tool rest provides durability and stability for tool support.
Powered by a 1.5kW induction motor with a VFD frequency converter, this lathe delivers high torque at low speeds, perfect for demanding tasks. The VFD frequency converter is a key component that enhances the lathe's performance by adjusting the frequency and voltage supplied to the motor. This results in smooth and efficient operation, even at low speeds. The ability to deliver high torque at low speeds is particularly beneficial for demanding tasks, such as turning large or unbalanced pieces of wood. It ensures that the lathe can handle heavy-duty work without compromising on power or stability.
The speed range can be changed with a clever one-lever mechanism, and the digital speed readout offers precise control over spindle speed. The projected nose cone allows for greater work access and wider bearing spacing, enhancing your working experience. The swing-away tailstock provides convenience when working on larger pieces, and the 800mm swing-away bed extension allows for turning longer workpieces. Additionally, the optional accessories are available; bed extensions and additional support leg as well as a riser kit to increase height. Copy pins that allow you to mount a template so you can visually follow a design (brackets are already fitted to the lathe) and a mobility kit facilitates easy movement of the lathe around your workshop, making it a versatile and indispensable tool for any woodturner.
Supplied with 2MT four prong drive centre, 2MT revolving tail centre, 75mm (3") diameter faceplate, knock-out bar, onboard storage for accessories, 1.8m power cable with UK 3 pin plug. For serious home workshops and professionals, the Laguna 18|36 Woodturning Lathe is more than just a tool - it's an investment in quality and precision. Elevate your woodturning projects to new heights with the Laguna 18|36 and experience the difference that professional-grade equipment can make.
Axminster Tools offers an optional 2-year extended warranty on all Laguna machines, ensuring peace of mind and comprehensive coverage. This extended warranty must be purchased at the same time as your Laguna machine. Please see the warranty link below for more details.
