Laguna 24|36 Woodturning Lathe 230V
From £3,921.98 £3,268.32
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • Bowl turning capacity of 600mm diameter allows for larger projects
  • Heavy cast-iron bed ensures maximum stability and minimal vibration
  • Self-ejecting tailstock with long quill travel extends reach and usability
  • Forward and reverse rotation enhances versatility and finish quality
  • Indexing positions at 14, 36, and 48 for precise and repeatable patterns
  • Powerful 2.2 kW induction motor with VFD frequency converter
  • Digital speed readout allows for precise control and speed monitoring
The Laguna 24|36 Woodturning Lathe is a powerhouse that caters to both specialists and woodturning professionals. With its exceptional bowl turning capacity, powerful 2.2kW induction motor, and high-quality construction, this lathe offers unparalleled performance and versatility. Whether you're working on delicate details or large, unbalanced pieces, the Laguna 24|36 ensures smooth, precise, and efficient operations. Experience the ultimate in woodturning craftsmanship with this innovative and robust lathe.
The 24|36 lathe offers 910mm between centres as standard an impressive bowl turning capacity of 600mm diameter over the bed, making it perfect for tackling larger projects with ease. This increased height not only enhances versatility but also ensures greater comfort during your woodturning tasks, allowing you to achieve professional results with minimal effort.
Equipped with a 2.2kW induction motor and a VFD frequency converter, the Laguna 24|36 delivers high torque at low speeds, ensuring smooth and precise operations. The high-quality ASTM A36 steel bed is precisely ground for smooth travel, while the cast-iron headstock and tailstock with banjo offer strength and low vibrations for a stable working environment.
The one-step cam handle allows for easy belt adjustments, and the variable speed control is perfect for delicate work, large diameters, or unbalanced pieces. The self-ejecting tailstock, with a quill travel of 114mm, enhances usability and diversity, making your woodturning experience more efficient. The floor to spindle centre height of 1,130mm is designed to provide an ergonomic working level, reducing strain and fatigue so you can focus on your craft. This versatile height allows the lathe to handle a variety of woodturning tasks, from delicate, intricate pieces to larger, more ambitious projects.
With forward and reverse rotation, the Laguna 24|36 provides versatility and a superior finish quality. The 14, 36, and 48 position spindle indexing allows for detailed and repetitive tasks, while the spring-loaded spindle lock ensures safe and accurate operations. Soft-grip cam action levers provide comfortable and secure handling on headstock tailstock and banjo, the tool rest as supplied is 305mm in length and has a hardened steel leading edge for durability. whilst the banjo has a 45Ëš cutout, wide base, with large eccentric rod diameter and hanger resulting in very positive lock. The projected nose cone allows for greater work access and wider bearing spacing, making this lathe a must-have for any woodturning enthusiast.
For dedicated home workshops and professional woodturners alike, the Laguna 24|36 Woodturning Lathe stands as a testament to quality and precision. Investing in this machine is not just about acquiring a tool, it's about committing to excellence in your craft. Elevate your woodturning projects with the 24|36 and witness the remarkable difference that professional-grade equipment can bring to your craft.
Supplied with 2MT four prong drive centre, 2MT revolving tail centre, 75mm (3") diameter faceplate, knock-out bar, onboard storage for accessories, 1.8m power cable with industrial 16 amp plug.
N.B. This Machine requires a 16amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
Axminster Tools offers an optional 2-year extended warranty on all Laguna machines, ensuring peace of mind and comprehensive coverage. This extended warranty must be purchased at the same time as your Laguna machine. Please see the warranty link below for more details.
Warranty Laguna 1 Year Warranty, Axminster Tools Extended 2 Year Available
Laguna Machine Warranty Options
Laguna 1-Year Warranty
The standard 1-year manufacturer's warranty for Laguna machines guarantees satisfactory quality, fitness for purpose, freedom from material defects, and compliance with UK regulations.
Axminster Tools Extended 2-Year Warranty
Enhance your peace of mind with Axminster Tools' optional 2-year extended warranty on all Laguna machines. This extended warranty, is only available for purchase at the time of purchasing your Laguna machine. It ensures comprehensive coverage for any defects in workmanship, parts, and materials for a full two years from the original invoice date. With this extended warranty, you can rest assured that any faulty part will be repaired or replaced at no cost to you, providing you with the highest level of support and protection on your investment.
Choose Axminster Tools' extended warranty and enjoy the confidence of knowing your Laguna machine is backed by exceptional service and care. Find out more
