Laguna C|Flux 1 Cyclone Extractor 230V
From £1,542.98 £1,285.82
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • Two-stage filtration system separates fine dust from larger waste chippings.
  • Twin outlet design with two 100mm outlets and an optional single 150mm outlet.
  • Sturdy steel frame with a wheel kit for high portability.
  • Easy bag change feature for coarse waste minimises downtime.
  • 1 micron pleated filter with a cleaning paddle for high-efficiency dust capture.
  • Remote control for effortless operation from a distance.
Powerfully mobile
Laguna dust extractors offer high-efficiency, top-quality extraction in a mobile design.
Superior cyclone performance
Two-stage separation of chips, shavings, and fine dust particles.
High-quality filtration
1-micron pleated, to maximise airflow.
Smart lift chip drum
Engages with a simple lever action, complete with level senses.
Efficient manual cleaning
Dual paddle design, rotated by a crank.
Remote control
Easy operation from a distance.
Axminster Tools Extended 2-Year Warranty
Choose Axminster Tools' extended warranty and enjoy the confidence of knowing your Laguna machine is backed by exceptional service and care.
Find out more
Unlock the full potential of your machine
With the extensive range of Laguna accessories
See the accessories
The Laguna C|Flux 1 Cyclone Dust Extractor is a superior solution for maintaining a clean and efficient workspace. It effectively separates heavy waste material from fine dust before the airflow reaches the fan, enabling the fan to operate more efficiently at a consistent speed. This advanced dust extractor is designed with the user in mind, offering a range of features that ensure superior performance and convenience. This high-efficiency particulate air filter with a high filtration level of 99.7% at 1 micron particle size that ensures fine dust particles are captured, providing a healthier working environment.
One of the standout features of this extractor is the 1 micron pleated filter, which comes complete with a cleaning paddle. The cleaning paddle makes maintenance a breeze, so you can keep your extractor running at peak performance. The remote control feature adds an extra layer of convenience, allowing you to operate the machine effortlessly from a distance.
The twin outlet design, featuring two 100mm outlets and an optional single 150mm outlet, provides versatility and allows you to hook up the extractor to a large machine with ease. The chute is designed to maximise airflow, with the fan housed inside a single horizontal plenum, reducing airflow resistance.
The larger waste is collected in a drum that has an innovative lift system allows for easy attachment or detachment with a simple lever. The drum, which is octagonal in shape, is raised off the ground and securely seals against the lid. When elevated, the CFLUX1 can be effortlessly moved on its four sturdy castors attached to the frame. Once lowered, the drum rests on another set of wheels, making it easy to roll to the desired emptying spot.
With the Laguna C|Flux 1 Cyclone Dust Extractor, you get a powerful, efficient, and user-friendly solution that enhances your workspace and promotes a healthier working environment. Experience the difference with Laguna – the ultimate solution where quality seamlessly meets innovation.
Axminster Tools offers an optional 2-year extended warranty on all Laguna machines, ensuring peace of mind and comprehensive coverage. This extended warranty must be purchased at the same time as your Laguna machine. Please see the warranty link below for more details.
Supplied with remote start handset, 1 collection bag for main drum, 1 collection bag for filter dust.
Warranty Laguna 1 Year Warranty, Axminster Tools Extended 2 Year Available
Laguna Machine Warranty Options
Laguna 1-Year Warranty
The standard 1-year manufacturer's warranty for Laguna machines guarantees satisfactory quality, fitness for purpose, freedom from material defects, and compliance with UK regulations.
Enhance your peace of mind with Axminster Tools' optional 2-year extended warranty on all Laguna machines. This extended warranty, is only available for purchase at the time of purchasing your Laguna machine. It ensures comprehensive coverage for any defects in workmanship, parts, and materials for a full two years from the original invoice date. With this extended warranty, you can rest assured that any faulty part will be repaired or replaced at no cost to you, providing you with the highest level of support and protection on your investment.
Choose Axminster Tools' extended warranty and enjoy the confidence of knowing your Laguna machine is backed by exceptional service and care. Find out more
