Precision and power for the perfect grind
The Laguna G8 Grinder offers reliable performance and smooth operation, making it a great addition to any home workshop for sharpening chisels, turning tools, and plane irons with ease and consistency.
Dual-speed capabilities
Switch between 2,890rpm for fast stock removal and 1,490rpm for controlled, precise sharpening and polishing.
Extra-wide adjustable Tool Rests
Generously sized for stability and equipped with lever-and-knob adjustment, allowing easy fine-tuning.
200mm x 25mm Aluminium Oxide Wheels
Includes 60-grit for rapid material removal and 120-grit for fine sharpening - offering both power and precision.Â
Flexible LED light
Bright, adjustable lighting improves visibility at the grinding surface for safer, more accurate work.Â
Adjustable spark deflectors and 3X magnifier-equipped eye shields
Provides added protection while enhancing detail visibility for intricate sharpening tasks.
Heavy duty cast-iron base
Delivers rock-solid stability and absorbs vibration for smoother, more controlled operation.
Stable, low-vibration design
Rubber feet reduce movement and noise, while integrated mounting slots let you secure the grinder for added stability and control.
Long-lasting performance features
Diamond dressing tool keeps wheels true and industrial-grade bearings reduce vibration and extend machine life.Â
Axminster Tools Extended 2-Year Warranty
Choose Axminster Tools' extended warranty and enjoy the confidence of knowing your Laguna machine is backed by exceptional service and care.
Unlock the full Laguna range
Whether you're a hobbyist creating fine woodwork or a production manager demanding precision and efficiency, Laguna offers solutions that empower you to bring your vision to life and enhance productivity
