Laguna Revo 12|16 Woodturning Lathe 230V
From £889.98 £741.65 was £1,017.98 £848.32 Save £128.00 £106.67
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • Heavy cast-iron bed for stability and reduced vibrations
  • Robust headstock, tailstock, and banjo construction
  • 1-step cam handle for fast belt changes
  • Self-ejecting tailstock with long quill travel
  • Forward and reverse rotation for enhanced versatility and finish
  • 24 position spindle indexing for precise positioning
  • Spring-loaded spindle lock for secure operations
  • Soft-grip cam action levers for comfortable handling
  • M33 x 3.5mm spindle thread
Powerful precision in every turn
From compact versatility to large-scale capability, each Laguna lathe is engineered with precision, power, and user-centric design for an unparalleled turning experience.
Cast-iron bed
Ensures stability and precision
Cast iron headstock, tailstock and banjos
Gives strength and low vibration
Belt change lever
Offers quick adjustment
For added versatility
Indexing positions
Improves detail in project designs
Enhanced safety
Projected nose cone with dual bearings
Gives additional accuracy and better work access
Axminster Tools Extended 2-Year Warranty
Choose Axminster Tools' extended warranty and enjoy the confidence of knowing your Laguna machine is backed by exceptional service and care.
Find out more
Unlock the full potential of your machine
With the extensive range of Laguna accessories
See the accessories
Laguna Revo 12|16 Lathe Woodturning lathe is a perfect blend of strength, precision, and user-friendly features. Engineered for precision and ease of use, this lathe combines robust construction with innovative features to deliver exceptional performance. The heavy duty heavy cast-iron bed, headstock, tailstock and banjo ensures stability and reduces vibrations, providing a smoother operation on all of your woodturning projects. Whether you're a seasoned professional or a passionate hobbyist, this lathe offers the stability, versatility, and performance you need to achieve outstanding results.
One of the standout features is the 1-step soft grip cam handle that allows for quick and easy belt changes, saving you time and effort. The self-ejecting tailstock with long quill travel enhances the diversity and usability of your woodturning tasks. Additionally, the lathe offers forward and reverse rotation, giving you versatility in your turning operations. The machine will also take an accessory ASR locking ring that will give greater safety by locking the chuck and spindle together.
The lathe's speed is monitored and automatically adjusted to maintain a constant speed, thanks to the pulse width modulation system (PWM). This system delivers a series of voltage pulses to the motor, continuously monitoring and adjusting the speed to maintain a constant rate. This ensures an impressive level of torque, even at the remarkably low speed of 50rpm, resulting in an optimal performance at all times.
The digital speed readout allows you to monitor the speed accurately. The anodized aluminium plate features ergonomically positioned controls, and the tactile, rubber-augmented knurled aluminium dial provides smooth and enjoyable variable speed control. The projected nose cone improves stability by enhancing access to the workpiece and providing wider bearing spacing. This design helps to reduce vibrations and ensures a more stable and precise operation, especially during delicate tasks.
For precise positioning, the 24-position spindle indexing is a valuable feature, enabling detailed work and repetitive tasks. The spring-loaded spindle lock ensures secure locking for safe and accurate operations. The soft-grip cam action levers provide comfortable and secure handling during adjustments, while the hardened steel leading edge tool rest offers durable support for your turning tools.
Supplied with 2MT four prong drive centre, 2MT revolving tail centre, 75mm (3") diameter faceplate, 1.8m power cable with UK 3 pin plug. Unlock your full potential with the Laguna Revo 12|16 and take your woodturning craftsmanship to unparalleled heights.
Axminster Tools offers an optional 2-year extended warranty on all Laguna machines, ensuring peace of mind and comprehensive coverage. This extended warranty must be purchased at the same time as your Laguna machine. Please see the warranty link below for more details.
Warranty Laguna 1 Year Warranty, Axminster Tools Extended 2 Year Available
Laguna Machine Warranty Options
Laguna 1-Year Warranty
The standard 1-year manufacturer's warranty for Laguna machines guarantees satisfactory quality, fitness for purpose, freedom from material defects, and compliance with UK regulations.
Enhance your peace of mind with Axminster Tools' optional 2-year extended warranty on all Laguna machines. This extended warranty, is only available for purchase at the time of purchasing your Laguna machine. It ensures comprehensive coverage for any defects in workmanship, parts, and materials for a full two years from the original invoice date. With this extended warranty, you can rest assured that any faulty part will be repaired or replaced at no cost to you, providing you with the highest level of support and protection on your investment.
Choose Axminster Tools' extended warranty and enjoy the confidence of knowing your Laguna machine is backed by exceptional service and care. Find out more
