PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
21.9% APR (variable)
Purchase interest rate
21.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
This is an industrial CNC milling cutter 10mm diameter. The CNC cutting of the recess for the Cabineo body can be done either from the top with a 15mm CNC drill bit or from the side using a CNC milling cutter.
Lamello produce the drill and a choice of cutters to suit the requirements of a variety of CNC machines. Fully dimensioned drawings are available for programming the CNC machine for each of the milling cutters and the drill option.
