Lamello Cabineo X 8 M6 Screw (Pack 500)
- Designed for use with the Lamello Cabineo X connectors
- Have a high clamping force for corner or dividing panel joints
- Insert into the open housed, Cabineo X connectors with ease
Lamello Cabineo Cover Caps Papyrus White RAL 9018 100 PceFrom £10.78 £8.98
These Lamello Cabineo 8 M6 Screws are designed for use with the Lamello Cabineo X connectors and create strong, reliable joints. With a high clamping force, they are suitable for corner joints where the counterpart material is a minimum of 9mm, or dividing panel joints where the counterpart material is a minimum of 16mm. Perfect for the easy installation of shelves. Insert into the open housed Lamello Cabineo X connectors and screw into the material.
Suitable for a variety of materials including chipboard, MDF, plywood, soft and hard woods.
Includes 500 x Cabineo 8 M6 Screws, 1 x Cabineo X Screw in aid and 1 x Cabineo hexagon bit 1/4" GL 80mm.
EAN Barcode | 7640149939828 |
Model | Cabineo X |
- Standard Delivery* - Free
