This is a truly amazing connector with a host of uses. Lamello has overcome many design assembly problems with this clamping connector; it is almost totally invisible, only a single 6mm hole shows. The Clamex P is a biscuit shaped fitting with a ‘T’ profile that slides in place, no screws or glue are needed. Having a pivot lever and two alignment studs, this lever is driven using a hexagon key though the 6mm hole, locking the fitting together forming a very secure joint. Ideally suitable for connections up to 45 in 18/19mm panels and for 90 connections in 16mm panels. The required slot is cut using a Lamello Zeta biscuit jointer specially developed for this application, cutting the slot and adding the ‘T’ to the bottom using a unique vertical mechanical drive. Made from fibreglass reinforced plastic, lever zinc die-cast for strength (tensile fitting strength 1000N = 100kg). Overall length is 66mm x width 27mm, each half has a depth of 14.5mm and it is 7mm in width (9.7mm o/a with ‘T’). Supplied as a pack of 80, 300 or 1000.
Pack Quantity 80
Web Attribute Set Biscuit Jointer Accessories
EAN Barcode 7640149930245
