For our latest updates about delivery and stores, click here
Lamello Classic X Biscuit Jointer in Systainer Case
719453
£549.96 £458.30
Low stock
- get it tomorrow, Thursday 9th Jul, order within and choose Premium delivery. Delivery info
  • Swiss made precision jointer
  • Swivelling front stop with fixed pivot, 0 - 90° with indents
  • Depth adjuster with 6 preset cutting depths
Customers Also Bought
Total: £1,146.35
Lamello invented the biscuit jointer and, as with all Lamello products, precision is the key.
The Classic X has a 780W industrial motor. CNC machined fences give accurate alignment, so you can take full advantage of connectors that can be glued, self-clamped or be detachable.
The main features are a swivelling front stop and the stop square. Both sides of the fences are flush for simple alignment. The multifunctional stop square gives more stability when working vertically, allowing variable height positioning and instantly aligns 22.5° and 45° angles.
The swivelling base can be set at any point between 0 - 90° (22.5°, 45°, 67.5° and 90°) and used with or without the stop square for angle locations. If this fence is mounted on the fixed base and the swivel set at 90°, a very secure platform is established for narrow edge work. Scales on both the angle and height adjustment are in metric and a very clear central marker is embossed into the baseplate. There is a choice of 6 preset depths for the common biscuit/connector sizes with further fine adjustable if required. The body of the machine is slim with a positive ‘D’ handle for the best grip.
The machine is supplied in a Lamello Systainer case with a 36mm suction stub, stop square, 4mm spacer, tool set and manual.
  • Stop square for variable height positioning, extra stability when vertical
  • CNC machined base with flush sides for easy alignment
  • Extra thin anti-slip pad for 12mm panels
  • Supplied with TCT scribing blade, 36mm dust outlet and 4mm spacer
  • Lamello Systainer case
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolYouTubeThe logo for YouTube
