Lamello Divario P-18 Installation Tool
101282
From £90.48 £75.40
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Available to Order
Delivery
Free Standard Delivery*.
Delivery time is approximately 3 weeks.
  • Ensures correct alignment of the Divario connector
  • Sharp hammer blow sets the positioning pins
  • Divario makes a strong joint with no visible connectors or shelf supports
  • Min shelf thickness: 18mm; min thickness for butt joints 12mm
  • P-System slot cut with either Lamello Zeta P2 or with factory CNC machine
  1. Lamello Divario P-18 Installation Tool
Total:
£132.26 £110.22
After placing the main body of the Divario P-18 connector into its slot, this installation tool ensures that the alignment of the body of the connector is correct. A sharp tap with a hammer sets the positioning pins, keeping everything in the perfect position.
Divario connectors allow easy installation of dividers or shelves into a fixed frame or structure. The result is a strong joint with no visible connectors or shelf pin supports. Slide the shelf into place and the Divario forms a tight fitting, flush joint. The Divario P-18 supports the shelf or divider during insertion, making assembly even more straightforward. Final assembly requires no further use of tools, glues or clamps. In this respect the connector makes possible assembly on site, as the transport of parts in flat pack form is an easy option.
This narrow connector allows use in shelves from 18mm thick and or butt joints for uprights in as little as 12mm thick. The Divario P-18 is a completely concealed connector. It results in a clean appearance thanks to closed joints and allows greater design freedom without sacrificing stability. Cut the P-System groove for the connector either manually in a workshop or on site using a Lamello Zeta P2 machine or with CNC machinery in a factory.
