£400.88 £334.07
Low stock
- get it tomorrow, Wednesday 30th Sep, order within and choose Premium delivery. Delivery info
  • Make precise dowel joints, no need to mark or measure
  • Align plate using pins, insert bush and drill.
  • Exact transfer of hole position to matching components
Customers Also Bought
This is a very clever jig and will allow you to very accurately position holes in the exact place and reposition on an opposite member if required for dowelling. Simple to look at and use the secret is in the precision with which the jig has been made that ensures accurate hole position every time, especially designed for the Lamello Invis system it can also be used for other drill and dowelling hole positioning.
A network of holes in the jig and pins are used as reference stops against your work so no matter what the shape the hole position can be repeated. Simply choose the correct drill bush and screw this into the jig so that it will guide your drill bit. Once drilled, remove pins and bushes, relocate in the same holes, protruding from opposite side of the plate, this then guides the plate and drill in place for an exact mirror hole position. The Duo kit contains; 2 Drill plates, 6 guide pins, drill bits 5, 8, and 12mm with stop collars and guide bushes 5, 8, 10 and 12mm, jointing bar and all packed in a Systainer case for storage.
  • Guide plate with multiple holes to position jig using pin stops
  • Idea for shaped profiles such as dowelling handrails
  • Joining bar for longer hole spacing
  • Drill bushes screw securely in plate and guide drill bit
  • Duo kit contains, Drill plate, 3 guide pins
  • Drill bits 5, 8 and 12mm diameter with stop collars, guide bushes
  • Jointing bar and Systainer case
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
