Lamello Zeta 5mm Positioning Pins (Pkt 2)
110839
110839
Next Day Delivery from £8*.
Order within
for delivery tomorrow, Wednesday 22nd Jan
for delivery by
Thursday 23rd Jan
- For use with the Lamello Zeta P2 Biscuit Jointer
- Achieve accurate alignment results
- High-quality positioning pins that will last
Lamello Zeta P2 Biscuit Jointer in Systainer Case with Diamond BladeFrom £1,445.98 £1,204.98
Lamello Zeta P2 Cordless Biscuit Jointer Set 18V (4.0Ah)From £1,877.98 £1,564.98
Show more
Show less
These Lamello Zeta 5mm positioning pins are for use alongside the Lamello Zeta P2 Biscuit Jointer, to accurately cut P-System grooves that are required in the middle of a surface. Using a CNC machine, drill two 5mm holes spaced at 101mm apart, and insert the pins. Finish the cut by inserting the Lamello Zeta into the drilled holes to achieve precise alignment.
EAN Barcode | 7640129668373 |
Model | 251048 |
Pack Quantity | 2 |
- Standard Delivery* - £4
