PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
21.9% APR (variable)
Purchase interest rate
21.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
Six decades after inventing the original biscuit jointer, Lamello has developed a cordless Zeta P2. This cordless Zeta P2 adds a new dimension to an already magnificent invention. It is designed and produced with the same care and precision as Lamello’s mains powered machines. Here you have a Swiss made cordless Zeta P2 with the freedom and convenience of a battery powered tool combined with all the functions and features of the mains powered version.
The Zeta P2 features diamond tipped blade and a special undercut function, unique to Lamello. This function produces a T-slot allowing you to use Clamex P concealed clamping connectors and many other types of useful and unique connectors such as Tenso and Bisco. These connectors can save a great deal of time when making cabinets and similar furniture items. There is no need for clamps and unsightly screws, panels go together quickly, accurately and securely. The P-System depth adjuster has five settings for the ever growing range of Clamex connectors.
The undercut function can be switched off and a 7mm slot will be produced for a 'Bisco' biscuit. Replace the special blade with a 4mm biscuit blade and use the Zeta P2 for standard biscuit jointing.
As with all Lamello products, design and build are of the highest quality. Other features include precise plunge with clear depth setting and jointer fences with flush sides to make positioning simple. The fence fits with 'V' grooves for accuracy and clear angle scale.
An added bonus comes in the form of the Lamello batteries. These are LIHD and have the common CAS (Cordless Alliance System) fitting. The CAS fitting is now the standard for over 30 European manufacturers (and growing). CAS already includes Mafell and Metabo.
Note this is a body only tool in a Systainer T-LOC case and supplied without batteries or charger.
Special ultra long lasting diamond tipped blade
Unique dual function cordless biscuit jointer
Saves time and overcomes many design problems
Produces special 'T' slot for Clamex P connectors
Wide range of different connectors available
Super precision, Swiss made power tool
Proven design, highly versatile, assured quality
CAS (Cordless Alliance System) common battery fitting
