Co-Matic TK 65 Dual End Cutter
505082
505082
Next Day Delivery from £8*.
Order within
for delivery by Tuesday 18th Feb
for delivery by
Wednesday 19th Feb
- The perfect tool for cutting edgebands or edge tape
- Designed for both professional and hobby use
- Makes aligned cuts without the need for changing any components
- Unique two-point support design ensures perfectly connected, aligned cuts
- It can handle material up to 3mm thick and 62mm wide
- The ergonomic handle make use a pleasure
Show more
Show less
The TK 65 Dual End Cutter is the perfect tool for cutting edgebands or edge tape. Designed for both professional and hobby use, this end cutter makes aligned cuts without the need for changing any components or using any additional guides. It has a unique two-point support design to ensure perfectly connected and aligned cuts. It can handle material up to 3mm thick and 62mm wide, whilst the ergonomic handle makes it a pleasure to use.
Corded or Cordless | Corded |
EAN Barcode | 5052511060467 |
Model | TK 65 |
Nett Weight | 0.5kg |
Overall L x W x H | 240 mm x 160 mm x 17 0mm |
Rating | Trade/Professional |
- Standard Delivery* - Free
