Mafell LO65EC Plunge Router (1/2")
108501
From £1,089.98 £908.32
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Available to Order
  • Powered by 2.600W CUprex, the high-performance motor
  • 65mm plunge depth
  • Fine height and fine fence adjustment, 3-turret depth stop
  • Constant electronic with high torque
  • Effective dust extraction connection
  1. Mafell LO65EC Plunge Router (1/2")
Total:
£3,049.92 £2,541.60
The Mafell LO 65 Ec router is powered by a high performance, high power, high torque, CUprex motor. This router will handle whatever task it is put to and with power to spare.
The LO 65 Ec features constant electronics to maintain speed under load. The speed is variable from 10 to 22 thousand rpm for perfectly matching the cutter/profile to the material, producing optimum results. The body of the router has a speed guide table for hardwood, softwood and plastics against cutter diameter.
The build quality is second to none, strong and robust without sacrificing refinement and precision. Fine depth and fine fence control come as standard. The LO 65 Ec router is a tough tool capable of the most demanding routing tasks, whilst retaining fine control for fine work.
Supplied with: Parallel guide fence with fine adjustment, 30mm template guide bush, 1/2" collet, dust extraction shroud, tools and instruction manual. Packed in a T-MAX power tool case.
Warranty Mafell 3 Year Warranty (Registration Required)
Register on the Mafell website and select NMA Agencies, Brighouse from Dealer options.
In case of a warranty claim please contact NMA Agencies NMA Customer Service Team on - Tel: 01484 400488
For warranty issues outside of the UK, tools must be returned to the UK at the customer's own cost.
Register now
