PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
21.9% APR (variable)
Purchase interest rate
21.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
The Mafell LS 103 Ec Chain Morticer has a 2,500W powerful motor for rapid progress through the timber. There is plenty of power here to cut into green oak with ease. Its ergonomic handle and switch arrangement offer safe, efficient, energy-saving working. Weighing in at only 8.7kg makes it easier to handle in site working situations.
The LS 105 Ec comes with a long guide plate with a large adjusting range, permitting work on large timber workpieces. The standard chain cuts a mortice 40mm wide by 28mm long and up to 150mm deep. Simply move the machine along for repeat cuts to extend the length of the mortice. The LS 103 Ec is ideal for precise framing work.
Initial assembly is very straightforward, in no time at all you’ll be up and running. The tensioning system of the LS 103 Ec allows fast chain replacement. Even retightening of the chain without removing the chain guard is quick and easy. The machine comes with a 10m long heavy duty cable, so there should be little need for extension leads even when on site.
This is a great value product, very well built as you would expect from Mafell, it performs beautifully and very accurately.
