Spread the cost of orders up to £15,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £15,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
For guaranteed perfect straight or angled cuts on site or in your home workshop, the MT 55 CC is the ideal machine.
Precise
Unrivalled cutting performance on or off the rail, the MT 55 CC executes accurate cuts every time. This is made possible by the tracking pointer, which moves with the blade tilt to allow you to see the exact cutting angle. An undercut facility is also available.
Versatile
Allowing you to make plunge, crosscuts, rip cuts and bevel cuts with ease, the MT 55 CC can be utilised for a multitude of different tasks whether you are on site or in a home workshop.
Variable speed
Thanks to the CUprex-Compact motor featured in the MT 55 CC, you can select your cutting speed and therefore tackle a wide range of different materials and thicknesses.
Easy
The MT 55 CC is easy to set up, accurate and reliable. A welcome addition to your toolkit, you won’t be disappointed with this saw!
The build quality, accuracy of the cut and ease of setup makes this plunge saw a joy to use. For carpenters and joiners, in the workshop or out on site, the MT 55 cc excels as a plunge cutting circular saw whether on or off a guide rail.
The powerful CUprex-Compact motor and continuously variable speed allows for a variety of blade options for cutting different thicknesses and different materials. Blade changes on the MT 55 cc are fast and simple. This all-round machine has some unique features; a tracking pointer moves when tilting the blade to indicate the exact position of the cut line at any angle. The scoring function enables you to produce a perfect finish in any material. A -1° undercut facility is great for perfect butt joints (the full tilt range is -1° to +48°). The well positioned depth stop is fully adjustable to within a millimetre and adjustable for blade wear after sharpening. Everything a plunge saw should be.
Supplied with 48T saw blade and Mafell T-MAX case.
Please note this can be fitted to the Mafell guide rail system and is compatible with oher guide rail systems..
Execute plunge, crosscuts, rip and bevel cuts with supreme precision
Scoring facility for a perfect surface cut in any material
-1° undercut allows for the tightest, neatest butt joint possible
