Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
This Saw and Guide Rail Kit combine to give you the potential to make perfectly accurate straight cuts up to 3.2m long. The Guide Rail Kit comprises 2x 1600mm Guide Rails (F 160), 1x Joining bar (F-VS), pair of quick action guide rail clamps and 1x Carry/Storage bag
The MT 55 cc excels as a plunge cutting circular saw whether on or off the guide rail. The powerful CUprex-Compact motor and continuously variable speed allows for a variety of blade options for cutting different thicknesses and different materials. Blade changes on the MT 55 cc are fast and simple. This all-round machine has some unique features; a tracking pointer moves when tilting the blade to indicate the exact position of the cut line at any angle. The scoring function enables you to produce a perfect finish in any material. A -1° undercut facility is great for perfect butt joints (the full tilt range is -1° to +48°). The well positioned depth stop is fully adjustable to within a millimetre and adjustable for blade wear after sharpening. Everything a plunge saw should be.
The MT55 saw is supplied with a 48T saw blade and Mafell T-MAX case, the Guide Rail Kit consists of 2x 1600mm Guide Rails (F 160), 1x Joining bar (F-VS), pair of quick action guide rail clamps and 1x Carry/Storage bag
This product is classified as a Dropship product. Dropship products are usually
readily available and despatched directly from the manufacturer using the best delivery service
available. Despatch times can vary between manufacturers and delays may occur should stock become
unavailable. Please contact
customer services
for more information.
