PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
21.9% APR (variable)
Purchase interest rate
21.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
The Mafell NFU 50 Groove cutting machine offers great benefits and opens up numerous possibilities. Designed with rugged, high-quality and precision-made parts, it is entirely suited to the rigours of an enormous range of timber construction tasks. It has a lightweight magnesium die-cast housing and impact-resistant, fiberglass-reinforced components.
A highly efficient 2,300 CUprex motor drives the 163mm diameter, 60mm wide cutter head. Twelve 14mm square, solid carbide, indexable cutters produce accurate clean cuts in solid timber and board materials. The NFU 50 offers a massive 50mm depth of cut (44mm when using the cross cut track). It is supplied with the cross cut track which ensures exact 90° or angled cross cuts up to 45° up to 370mm long. The NFU 50 can be removed from the cross cut track at the single press of a button, allowing its use either freehand or on a guide rail.
A parallel fence guides longitudinal rebates. The cutter head can be angled up to 45 for cutting birdsmouth joints.
The large cutting capacity produces large volumes of debris, the 58mm hose connector rotates for the most convenient position. A brake stops the tool within 3 seconds, an LED lamp flashes indicating when the cutter is still turning.
Use the NFU 50 to cut:
Notches
Tenons
Rebates
Angled grooves up to 45°
Birdsmouth joints
Supplied with
1 Cutter head 163mm x 60mm
1 position indicator NFU-PA
1 Side fence SA 625
1 Parallel fence
1 Guide track L, max. range 370 mm
2 repeat fence stops
1 allen key 6mm
1 Screwdriver Torx T15
This product is classified as a Dropship product. Dropship products are usually
readily available and despatched directly from the manufacturer using the best delivery service
available. Despatch times can vary between manufacturers and delays may occur should stock become
unavailable. Please contact
customer services
for more information.
