Spread the cost of orders up to £15,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £15,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
In addition to the standard equipment this version includes the Tilting Base for exact bevel cutting ± 45° and an 800mm Guide Rail F 80. The Tilting Base simply clips onto the jigsaw replacing the standard base. The 800mm Guide Rail ensures clean and exact straight cuts. The upper surface of the rail has a special coating, which helps the jigsaw glide along whist a rubber edge strip provides tear protection.
Equipped with a Cuprex compact motor that delivers 900W of power and intelligent digital electronics to maintain speed under load, the P1 cc offers cutting depths up to 115mm. The base plate is compatible with other accessories in the Mafell F guide rail system for even greater cutting precision. The dust extraction uses the Venturi principle to maximise effectiveness and ensure the cut-line is free from debris at all times, even without attaching a vacuum extractor. The speed can be varied in a range from 800 to 3,000 strokes/min. With three oscillation settings and a zero setting, rapid progress in a wide variety of materials is assured.
The P1cc is compatible with Mafell Guide Rails and takes all standard bayonet fitting jigsaw blades, as well as the unique patented Mafell CUnex precision blades with a wedge shape design and extra strength.
