PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
21.9% APR (variable)
Purchase interest rate
21.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
The Mafell ZH 205 Ec beam planer with its 208mm planing width means you can plane large timbers with ease. It is well worth serious consideration from timber framers, carpenters, boat builders etc.
The front knob offers stepless planing depth adjustment up to 4mm. These impressive specifications are made possible by the 2,300W high efficiency motor running at 8,500rpm. Intelligent control electronics monitor performance ensuring constant speed under load. The electronics give you smooth start up and overload protection.
This is a solidly built machine designed for practical use and ease of handling. It features a large comfort grip front handle and weighs in at a manageable 12.5kg. The 10m power cord allows long passes without resorting to extension leads.
The chip ejector features enhanced air flow and through an air duct. The removal of large amounts of material never becomes a problem, even when planing unseasoned timbers. A special base plate structure ensures smooth movement and a ball bearing roller guide can be used to keep the machine on track by following an edge.
Easy-to-change reversible blades are a great aid to high productivity, no more time-consuming blade adjustments.
This product is classified as a Dropship product. Dropship products are usually
readily available and despatched directly from the manufacturer using the best delivery service
available. Despatch times can vary between manufacturers and delays may occur should stock become
unavailable. Please contact
customer services
for more information.
