PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
23.9% APR (variable)
Purchase interest rate
23.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
Spread the cost of orders up to £15,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £15,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
With the Mafell ZH 320 Ec beam planer with its 320mm planing width means you can plane large timbers with ease. It is well worth serious consideration from timber framers, carpenters, boat builders etc.
The front knob offers stepless planing, depth adjustment up to 3mm. These impressive specifications are made possible by the 2,700W high efficiency motor running at 8,500rpm. Intelligent control electronics monitor performance ensuring constant speed under load. The electronics give you smooth start up and overload protection.
This is a solidly built machine designed for practical use and ease of handling. It features a large comfort grip front handle and weighs in at a manageable 14kg. The 10m power cord allows long passes without restoring to extension leads.
The chip ejector features enhanced air flow and through an air duct. The removal of large amounts of material never becomes a problem, even when planing unseasoned timbers. A special base plate structure ensures smooth movement and a ball bearing roller guide can be used to keep the machine on track by following an edge.
Easy to change reversible blades are a great aid to high productivity, no more time consuming blade adjustments.
This product is classified as a Dropship product. Dropship products are usually
readily available and despatched directly from the manufacturer using the best delivery service
available. Despatch times can vary between manufacturers and delays may occur should stock become
unavailable. Please contact
customer services
for more information.
