Magic Gripper Door Clamps are an invaluable aid when planing new doors to size, adding locks or hinges or routing a groove for a smoke seal. They make holding a door far easier than fiddling about with bar clamps etc.
Magic Gripper Door Clamps have a strong construction and hold a door rock solid. They use the power of gravity to clamp a door or panel. There is quick adjustment for thickness from 15-55mm. Once adjusted, the jaws remain in the open position ready and waiting. On placing a door in the jaws, gravity takes over, the jaws automatically close and grip tightly. The heavier the door the tighter they grip. Any downward pressure, such as planing, only serves to increase the grip. To remove the door or panel simply lift and the jaws automatically open.
When not in use Magic Gripper Door Clamps take up little space in your van or shed. Supplied in pairs, one for the top and one for the bottom of the door, suitable for internal doors, fire doors, kitchen worktops etc.
Clamps doors or material securely from 15-55mm
Solid support for easy door preparation
Plane doors to size, fit locks and hinges, supplied as a pair
