Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Makita 3708F Trimmer (1/4")
Code: 300248
  • Doubles as a small router
  • Tilting base for chamfer work
  • Adjustable routing fence
  • Roller guide assembly
  • High intensity bulbs illuminate cutter and work
  • Supplied with router cutter, two collet spanners and 10mm template guide bush
  • Show More
£176.96 (£147.47 Ex. VAT)
Low stock - get it Tuesday 2nd Jun, order within and choose Premium delivery
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We'll aim to despatch your products the same day when you order before 4pm, Monday to Friday.
  • Standard UK (5-7 day) - free
  • Premium UK (next day) - from £6
  • International - available
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
  • Makita 3708F Trimmer (1/4")
  • Makita PJ7000 Biscuit Jointer 230V
  • Axminster Workshop Edgebanding Trimmer
  • Axcaliber Flush Cutter Bottom Bearing - D=12.7 - X=25.4mm - S=1/4"
Total: £399.52
Description
In Detail
Makita 3 Year Warranty (Registration Required)
This versatile little machine doubles as a small router for edge moulding, trimming and grooving or as a laminate trimmer complete with a tilting base for chamfer work. The combined guard and base unit is fitted with a height adjustment wheel to set the depth of cut and a quick action toggle clamp. The adjustable fence is used to set both the distance in from the edge of the work and the chamfer angle and has an integral handle for safe two-handed control. An edge follower roller guide is also supplied for trimming curves. An auxiliary side fence can be fitted to convert the machine into a small router for edge moulding, grooving and trimming applications. The machine is also fitted with a pair of high intensity light bulbs that illuminate the cutter and work piece.
Supplied with tilting trimming fence, router cutter, adjustable routing fence, roller guide assembly, two collet spanners and 10mm guide bush.
Information Downloads
Specification
Specification
Collets Supplied 1/4"
Corded or Cordless Corded
Fine Fence Adjuster Standard Equipment
Fine Height Adjuster Standard Equipment
Model 3708F
Motor Power 440 W
Nett Weight 1.2 kg
Rating Industrial
Sound Pressure Level [Uncertainty K] 80 dB(A) [3.0 dB]
Vibration Cutting Wood [Uncertainty K] 2.5 m/s² [1.1 m/s²]
Voltage 230 V
Plug Fitted UK 3 pin plug
Cutter Speed 35,000 rpm
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
