This well balanced planer features the latest maintenance free, brushless motor. The motor offers longer runtimes from a single battery charge and similar performance to a mains powered tool.
The DKP181 has a maximum depth of cut of 3mm with a width of 82mm and a rebate depth of up to 25mm. Depth adjustment is accurately controlled with a large front grip handle with scale adjusting in 0.01mm increments. The blades are tungsten carbide and reversible, the blade clamp system makes changing quick and easy. A small spring-loaded stand on the baseplate protects the blades and the work surface when putting the planer aside. Supplied as a body only, this tool comes without batteries or charger.
Brushless motor with electric brake and soft start
Allows up to a maximum 3mm cutting depth
Maximum rebate depth of 25mm
Automatically changes the cutting speed according to load
Left and right chip ejection
Base with 3 chamfering grooves
Depth of cut adjusted by simply turning the front knob
Spring-loaded stand elevates the base to protect the blades
Easy blade setting system for fast blade installation
The warranty period of your Makita tool may be extended to an additional 2 years subject to the following conditions:
Makita Tools that are CE marked and (with the exceptions of Batteries, Battery Chargers, Accessories, Petrol Products, Production Tools and Air Tools and Compressors) purchased on or after 1st July 2012.
The tool is registered by the end user within 30 days of purchase.
For more information and to register your product visit the Makita website.
N.B. Batteries and chargers 1 year warranty. For machines purchased in the UK but then exported, the standard 2 year warranty would apply.
