Put your spare LXT batteries to work. The Makita DML815 torch is compatible with ALL Makita 14.4V and 18V Li-ion LXT batteries. Its bright 160 lumen output lights up the darkest recesses and poorly lit work areas. The DML815 provides illumination, versatility, and convenience. It has a durable design, engineered for tough site conditions. It is easy to handle, slim and compact; approximately 270mm tall. The head pivots, with 12 positive stops from -60° to +110°. Wherever you point the light, is where it will stay. The 4 LED provides 160 lumen with a long runtime (23 hours from a 5.0Ah 18V battery), while the multi-faceted reflector gives a good spread of light. The handle has a comfortable rubberised grip. You can use the DML815 either standing upright on the battery base or hung overhead from the integral strap-hook.
Compatible with Makita 14.4V and 18V Li-ion LXT batteries
Durable for tough site conditions, long runtime, 160 lumen output
