At only 144mm front to back the Makita DTW300 is certainly compact. Delivering 330Nm of torque and with 580Nm of nut-busting, loosening torque it’s certainly powerful. This 18V cordless impact wrench features a maintenance-free and highly efficient brushless motor. The variable speed trigger can be changed to full speed mode, a shorter trigger travel means full speed is reached faster for improved productivity. 4-speed impact power selection offers plenty of choice for efficient fastening.
Other features include a bright twin LED lamp to illuminate the fastening area, auto-stop and auto-slowdown to prevent nut loss by running off the thread and an electronic brake for better control. The DTW300 has a 1/2" square drive and is suitable for standard bolts M10-M20 and high tensile bolts M10-M16. Takes Makita 18V Li-ion LXT batteries. Supplied as body only without batteries or charger.
Battery Voltage 18 V
Reverse No
Sound Power Level LwA [Uncertainty K] 108 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 97 dB(A) [3.0 dB]
Model DTW300Z
Drive 1/2 Square Drive
Impact Speed 0 - 1,000 rpm 0 - 1,800 rpm 0 - 2,600 rpm 0 - 3,200 rpm
Nett Weight 1.5 kg (without battery)
Vibration Fastening [Uncertainty K] 12.5 m/s [1.5 m/s]
Warranty Makita 3 Year Warranty (Registration Required)
EAN Barcode 88381898003
