Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Makita HP332DSAJ Brushless Combi Drill 10.8V
Code: 102684
  • All purpose drill that performs a variety of different functions
  • Cordless combi drill with 10.8V CXT slide type Li-ion battery
  • Compact and powerful with ergonomic soft grip
  • Brushless motor extends run time, maintenance free
  • 2-speed mechanical gearbox with variable speed trigger
  • Battery protection circuit protects battery against damage due to over discharge
  • LED job light and belt clip
  • Supplied with 2 x 2.0Ah batteries and 10.8V DC10SA fast charger
  • Comes in a type 1 MAKPAC connector case
  • Show More
Save £3.06
Last Few
NOW £166.90
Normally £169.96
(£139.08 Ex. VAT)
Out of stock
Sorry, this product is no longer available.
See Alternative Options
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
Makita 3 Year Warranty (Registration Required)
Makita’s CXT (Compact Extreme Technology) uses powerful 10.8V Li-ion slide batteries, featuring high capacity cells. They have multi-contact terminals to ensure stable contact even under extreme work vibration conditions. The slide battery fits easily into the tools and chargers. They have a high level of structural strength as well as having built-in protection to prevent overload or over discharging.
The HP332DSAJ Combi Drill uses the latest brushless motor technology. Brushless motors are virtually maintenance free. They are far more efficient than a brushed DC motor. As there is no brush to cause friction against the motor, your battery saves power giving you a run time up to twice as long. As expected, this tool has all the necessary features required by a professional user. The 10.8V battery provides masses of power yet the unit still remains compact and manageable. The overall length is only 168mm.
Supplied with 2 x 2.0Ah batteries, 10.8V DC10SA fast charger and a type 1 Makpac connector case. The DC10SA fast charger will charge 10.8v CXT slide batteries in the below times:
BL1015 - 22mins
BL1020B - 30mins
BL1040B - 60 mins
Specification
Specification
Batteries Included 2
Battery Capacity 2.0 Ah
Battery Type Li-ion
Battery Voltage 10.8 V
Chuck Capacity 0.8 mm to 10 mm
Chuck Type keyless
Corded or Cordless Cordless
Impact Rate 0 - 6,750 / 0 - 22,500 /min
Max Drilling Masonry 8 mm
Max Drilling Wood 28 mm
Model HP332DSAJ
Nett Weight 1.3 kg
Rating Industrial
Reverse Standard Feature
Sound Power Level [Uncertainty K] 93 dB(A) [3.0 dB]
Sound Pressure Level [Uncertainty K] 82 dB(A) [3.0 dB]
Torque 35 Nm
Torque Settings 20 + Drilling
Vibration: Drilling Concrete [Uncertainty K] 12.5 m/s² [1.5 m/s²]
Vibration: Drilling Metal [Uncertainty K] 2.5 m/s² [1.5 m/s²]
Max Drilling Metal 10 mm
Drilling Speed 0 - 450 rpm / 0 - 1,500 rpm
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
