Makita Portable Mitre Saw Stand WST06
- Folds for portability, twin castors and carry handle
- Quick release (tool-less) locking levers to install or remove mitre saw
- Arms extend to a maximum of 2,550mm
- One arm with roller the other with material stop for repeat cuts
- Maximum supported weight: 225kg
- Dimensions (open): 1,150 x 750 x 850mm
The WST06 stand is compatible with the following Makita mitre saws: LS0714, LS0815, LS1016, LS1018, LS1019L, LS1219L, LS1216, LS1040, DLS713 and MLS100. This folding stand with twin castors, carry handle and a weight of only 18kg is easy to transport or store (with or without the saw attached). Once unfolded, an adjustable levelling foot prevents the stand from wobbling on uneven floors or ground. Quick release (tool-less) locking levers enable you to quickly install or remove your mitre saw without the need for additional tools. The sliding rail lets you position anywhere along the bed of the stand. The arms extend to a maximum of 2,550mm. One arm features a roller whilst the other has a material stop for repeat cuts.
EAN Barcode | 088381442091 |
Model | WST06 |
Nett Weight | 15.3 kg |
Overall L x W x H | Open: 1,150 mm x 750 mm x 850 mm Collapsed: 1,270 mm x 270 mm x 250 mm |
- Standard Delivery* - Free
