The Makita RP2303FCJ 1/2" router offers masses of power combined with easy control for precise routing. This router features a powerful 2,100W motor and is fitted with an anti-restart switch to prevent unintended start-up in the event of a power outage. The RP2303FCJ has soft-start to minimise any initial ‘jerk’ when switched on. This and the variable speed of 9,000 to 23,000rpm make for a very controllable machine. The variable speed control enables you to match the speed to the size of the cutter. Whilst the constant speed control maintains speed under load.
Linear bearings ensure the 70mm plunge is particularly smooth. The RP2303FCJ has a 3-stage turret for incremental cuts to the full chosen depth. The depth adjustment scale is easy to read and adjust in 0.1mm increments for real precision.
Twin LED job lights illuminate the area around the cutter allowing you to see exactly what’s going on.
Supplied with a side fence with fine adjuster, 1/2" collet, 1/4" sleeve, dust shroud and wrench all in a robust Makpac 4 storage case.
Note: This router is fitted with an Anti Restart Safety Switch and is incompatible with a seperate external NVR switch.
Combines power and precise control
Twin LED job lights illuminate the cut line
Fine height adjuster and fine fence adjuster
Linear ball bearing for super-smooth plunge action
Ergonomically contoured knob style handles
Variable speed, soft start, constant speed under load
The warranty period of your Makita tool may be extended to an additional 2 years subject to the following conditions:
Makita Tools that are CE marked and (with the exceptions of Batteries, Battery Chargers, Accessories, Petrol Products, Production Tools and Air Tools and Compressors) purchased on or after 1st July 2012.
The tool is registered by the end user within 30 days of purchase.
For more information and to register your product visit the Makita website.
N.B. Batteries and chargers 1 year warranty. For machines purchased in the UK but then exported, the standard 2 year warranty would apply.
