Makita SP6000J1 Plunge Saw, 2 Guide Rails & Bevel Guide - PACKAGE DEAL
From £392.96 £327.47
  • Package deal comprises the Makita SP6000J1 Plunge Saw, 2 x Makita 1.5m Guide Rails, 1 x Makita Guide Rail Connector and the Makita Adjustable Bevel Guide for Guide Rail SP6000.
  • Makita SP6000J1 Plunge Saw
  • Precise plunge saw with many features
Customers Also Bought
Highly accurate and well built with many features for the most precise cut when ripping and crosscutting. Powerful 1,300W motor (overload protected) with constant electronics to maintain speed under load for a very smooth cut. A variable speed dial allows you to select correct speed for material being cut. Cutting up to 55mm depth and 39mm at 45°, a 2mm scoring cut can quickly be made before the full depth cut, height and angles (-1° - 48°) are simply set with thumb screws, with positive stops for -1°, 22.5° and 45°. Supplied complete with Systainer case.
Makita 1.5m guide rail for the Makita SP6000J1 plunge saw. Replaceable splinter guard, anti-slip strips on the underside and top running strips for a smooth glide.
Guide rail connector for Makita Guide Rail system.
A simple but accurate way to cut angles with your guide rail. Place the bevel guide against the edge of your material, pivot and lock to the required angle, attach to the guide rail and make your cut - it really is that simple. Graduated scale 0 - 45° left or right.
  • Soft start and constant electronics
  • Max depth of cut at 90° 55mm and at 45° 39mm
  • Clear scale for precise saw adjustment
  • -2° negative angle available, also pre-set 22.5°
  • Can perform a cut 18mm from a wall
  • Adjustment for perfect fit on rail
  • 3 year Makita warranty available (registration required)
  • Saw supplied in Systainer case fitted with 48t blade
  • Makita 1.5m Guide Rail
  • Makita 1.5m guide rail
  • For SP6000J1 plunge saw
  • Rail has anti-slip coating, so clamping not required
  • Makita Guide Rail Connector
  • Guide rail connector for Makita Guide Rail system
  • Makita Adjustable Bevel Guide for Guide Rail SP6000
  • Quick and accurate way to cut angles with your guide rail
  • Bevel guide sits against edge of work and also in rail slot
  • Pivot and lock to the required angle
  • Graduated scale 0 - 45° left or right
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolYouTubeThe logo for YouTube
