Micro-Mesh is a unique cushioned abrasive that produces a very fine and uniform scratch pattern.
If you finish to around 400g with standard abrasives then start using the 1,500g Micro-Mesh you should get excellent results. The 12,000g will leave a scratch pattern that cannot be detected by the human eye. Micro-Mesh offers outstanding results for a huge range of applications, and is proving to be extremely popular with pen turners, musical instrument makers, furniture restorers and anyone who requires a highly polished surface. A light touch works best. For excellent results with acrylics try wet sanding. You will wonder how you managed without them.
Supplied as a pack of nine double sided 50 x 50mm soft touch pads ranging from 1,500g to 12,000g. N.B. Colour chart provided is a guide only and pads may vary slightly in colour.
Abrasive Material Silicon Carbide
Abrasive Backing Foam
Pack Quantity 9
Web Attribute Set Jaws for Four Jaw Chucks
EAN Barcode 5052511111190
