Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Microplane Rotary Shaper
  • Requires very little sanding after use (finish sanding only)
  • Creates small shavings instead of dust for a healthier work environment
  • Can be used with either a drill press or a hand drill
  • Patented blade designs will not clog
  • Use on wood, plastic, platerboard, rubber & more instead of coarse sandpaper
  • Show More
£19.30 (£16.08 Ex. VAT)
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
Enjoy shaping with precision and control on wood, plastic, plasterboard, rubber and more instead of coarse sandpaper. Hundreds of razor sharp mini teeth in the form of a drum, for use with a power drill. Microplane blades are made from 400 series stainless steel and have been fitted to an aluminium extrusion which is provided with a 8mm shank. The beauty of this method of shaping is the resulting waste, which is tiny shavings rather than dust, and the superior finish left by a tool that cuts rather than scrapes, tears or abrades, creating clouds of dust. Recommended to run at between 1,000-2,000rpm and not exceed 2,500rpm. The Rotary Shapers rotate clockwise. Materials being fed into the shaper should be fed left of centre to reduce kickback. Available in two sizes 25mm(1") or 50mm(2"), with replacement blades available for both.
Promo
This product is on page 289 of the Axminster Tools & Machinery 2019/20 Catalogue.
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
