Mirka
Mirka 1230L PC Wet & Dry Extractor (L Class) with Hose
SKU: 107352
£489.98
£408.32 Excl. VAT
  • L-class extractor with manual or auto-start
  • 1,200W motor 4,500 l/min air flow and 30L capacity (wet)
  • Supplied with 4m x 27mm hose, connector and a fleece dust bag
  • Push and Clean filter cleaning for better performance and a longer life
  • Flat top design, Hose storage hooks to keep hose tidy
The Mirka 1230L PC wet and dry extractor is an L-Class machine fitted with a semi-automatic filter cleaning system, Push & Clean. Regular use of the filter cleaning feature maintains suction performance and increases the lifetime of the filter. The machine’s selector switch lets you choose between manual or auto-start. Choose the auto-start and the extractor only runs when the power tool is in use, reducing noise and extending the extractor lifetime. This extractor has a 1,200W motor and an air flow rating of 4,500 l/min. High performance comes as standard whether extracting directly from a power tool or cleaning up after a job.
The flat filter maximises available space within the 30-litre container, the filter is easily accessible for manual cleaning or replacement. The flat top design offers space for storage of tools, abrasives etc. The machine has facilities for neat onboard storage of both hose and cable, making it a tidy self-contained unit. Large front and back wheels mean the 1230 L PC is easy to manoeuvre on uneven floors. Dry capacity with the dust bag is approx 15 litres.
As with all L-Class vacuums the 1230L complies with strict standards. It is designed to pick up non-flammable liquids and non-hazardous dust Class L. Dust in this class has OEL values > 1 mg/m3.
The 1230L PC set comes complete with 4m x 27mm hose, connector and a fleece dust bag.
Overall L x W x H 565mm x 565mm x 385mm
Rating Trade/Professional
Corded or Cordless Corded
Cable Length 7.5 m
Airflow Volume 4,500 litre/min
Sound Pressure Level LpA [Uncertainty K] 59 dB(A) [2.0 dB]
Motor Power 1,200 W
Plug Fitted UK 3 pin plug
Web Attribute Set Vacuum Cleaners - Wet & Dry
EAN Barcode 6416868301359
