Mirka Abranet Abrasive Discs 125mm
- An incredibly efficient long lasting abrasive
- Open mesh design eliminates clogging
- Dust free sanding when used with extraction
- For woodworking, decorating and automotive use
- Gives uniform scratch free smooth finish
- Hook and loop backing
Abranet® is a revolutionary abrasive material offering dust free sanding with no clogging. The open mesh design features thousands of tiny holes which will make sure that when used with suitable extraction the passage of dust will be incredibly efficient. Because Abranet® abrasive keeps the surface that you are sanding dust free, this results in a very uniform scratch pattern leaving an ultra smooth finish. It is incredibly durable and will last twice as long as many conventional abrasives making it very cost effective. These hook and loop backed discs are suitable for a wide range of materials including the decorating, woodworking and automotive industries. We recommend the use of pad savers for prolonged pad life.
Abrasive Backing | Mesh and Hook and loop |
Abrasive Disc Diameter | 125 mm |
Abrasive Type | Abranet |
