Mirka Abranet Abrasive Sheets 70 x 125mm
- An incredibly efficient long lasting abrasive
- Features hook and loop backed open mesh design, eliminating clogging
- Dust free sanding when used with extraction
- Uniform sanding pattern and perfectly smooth surface
- Used for woods, GRP, composites, paint and plaster
- Good for cleaning corroded metals when used by hand
Abranet® is a revolutionary abrasive material offering dust free sanding with no clogging. The hook and loop backed open mesh design features thousands of tiny holes which will make sure that when used with suitable extraction the passage of dust will be incredibly efficient. Because Abranet® abrasive keeps the surface that you are sanding dust free, this results in a very uniform scratch pattern leaving an ultra smooth finish. It is incredibly durable and will last twice as long as many conventional abrasives making it very cost effective. These abrasive strips with hook and loop backing are suitable for a wide range of materials including those used in the decorating, woodworking and automotive industries.
Abrasive Backing | Mesh and Hook and loop |
Abrasive Sheet Size | 70 mm x 125 mm |
Abrasive Type | Abranet |
