Spread the cost of orders up to £15,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £15,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
The DEROS 350CV is unique; with a compact body, 77mm disc and low weight (only 0.8kg) it is the perfect small sander. In the DEROS 350CV, you have a low profile, easily manoeuvrable sander, with efficient extraction and minimal vibration levels. This 77mm sander with its user-friendly, compact body reaches small areas a regular sander cannot reach. The design makes it perfect for tackling small repairs, hard-to-reach areas, furniture restoration, painting prep, auto body dent and scratch repair and more. No more tired arms and wrists caused by holding a heavy awkward sander when sanding tricky areas.
The body of the machine houses a 250W brushless motor with soft start and electronic pad brake for controlled sanding. The variable speed has a range covering 4,000 to 10,000rpm, while the 5mm oscillation offers high stock removal rates.
It has the lowest vibration values in its class. You can monitor vibration levels in real-time with the myMirka app.
The Deco kit which comes with the DEROS 350V includes 50 Abranet Ace discs P80, 50 discs P120, 50 discs P180.
2+1 Extended Warranty for Mirka sanders, registration required within 30 days.
Registration is required within 30 days of purchase.
The Mirka 2+1 year warranty applies to Mirka sanders, dust extractors and polishers. If a problem occurs with a Mirka tool caused by a manufacturing defect material or by workmanship; Mirka will repair your tool free of charge in accordance with the warranty terms.
