Mirka DEROS II 750 Random Orbit Sander 175mm 230V
Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
- Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
- Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
- Professional-grade orbital sander
- 175mm sanding pad for quick task completion
- Powerful 400W brushless motor; consistent speed, reduced maintenance
- Bluetooth connectivity for monitoring vibration levels via the myMirka app
- Variable speed control for flexibility in different sanding tasks
- Ergonomic design for comfortable use over extended periods
- Compatible with Mirka dust extractors for efficient dust management
Mirka DEOS II 353CV 81 x 133mm Sander Deco Solution KitSpecial Price £532.96 £444.13 was £566.98 £472.48 Save £34.02 £28.35
Mirka DEOS II 663CV Delta Sander Deco Solution KitFrom £519.98 £433.32
The Mirka DEROS II 750 Random Orbit Sander 175mm 230V is a professional-grade orbital sander designed for efficiently sanding larger areas. With its 175mm sanding pad, this sander allows you to complete tasks more quickly and effectively. The powerful 400W brushless motor ensures that even tough sanding jobs are handled with ease, providing consistent speed and more power while requiring less maintenance and offering a longer lifespan.
Comfort and convenience are at the forefront of the DEROS II 750's design. Its ergonomic build ensures comfortable use over extended periods, and the Bluetooth connectivity feature allows you to monitor vibration levels through the myMirka app. Additionally, the variable speed control provides flexibility for different sanding tasks, making this sander a versatile tool for any professional or DIY enthusiast. Compatible with Mirka Dust Extractors, the DEROS II 750 is an excellent addition to your sanding toolkit.
EAN Barcode | 6416868201161 |
Motor Power | 400 W |
Nett Weight | 1.1KG |
Orbit Diameter | 5.0 mm |
Pad Size | 175 mm |
Sound Pressure Level LpA [Uncertainty K] | 71 dB(A) |
Vibration Sanding [Uncertainty K] | 2.8 m/s² |
Voltage | 230 V |
- Standard Delivery* - Free
