Mirka DEROS RS600 Rotary Sander 150mm with Deco Abrasive Kit 230V
112908
112908
From £598.98 £499.15
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Thursday 10th Jul
  • Experience powerful, smooth, and silent sanding
  • Ideal for heavy-duty, coarse grinding and sanding applications
  • Lightweight and low-profile design for easy manoeuvrability
  • Adjustable sanding speed with RPM LED indicator
  • Very low noise levels and minimal vibration for comfortable use
  • Includes ABRANET ACE HD sanding discs in P40, P60, and P80 grits (25 pk)
  • Designed with woodworkers and boat builders in mind
The Mirka DEROS RS 600 UK 150mm 230V Deco Solution Kit is a powerful and versatile tool designed for heavy-duty, coarse grinding and sanding applications. This kit is ideal for tasks such as paint stripping, micro-cement work, stair sanding, body in white, and teak decks. Despite its robust capabilities, the DEROS RS 600 maintains a smooth and silent operation, making it easy to manoeuvre and comfortable to use. The combination of power, lightweight design, and low noise levels make it suitable for both professional and DIY projects.
The kit includes the Mirka DEROS RS 600 sander, along with ABRANET ACE HD 150mm Grip sanding discs in P40, P60, and P80 grits. Key features of the sander include a powerful yet lightweight design, very low noise levels, and minimal vibration. The RPM LED indicator allows for easy monitoring of sanding speed, which is adjustable between 700 and 2,500 rpm. The included shroud guides dust in the right direction when sanding with a pad saver, ensuring a cleaner work environment. The momentary switch function and the special slow start feature add to the tool's ease of use. Additionally, the DEROS RS 600 is compatible with the myMirka app over Bluetooth® for monitoring vibration levels and other connectivity features.
Contents: Deros RS in Systainer case with 3 boxes Abranet ACE HD 150mm (25/pk-P40,P60,P80)
