A range of flexible, three dimensional abrasives suitable for almost any surface, be it woods, metals, paint, GRP or lacquer. It has many advantages over conventional abrasives in that the open web design is non-clogging, can be used wet or dry. It is ideally suited to flat or contoured surfaces. Perfect for keying surfaces and creates an excellent base for the next lacquer layer. Available in three different grades: 320g for general purpose use, 360g for denibbing finishes and 1,500g for blending, smoothing and polishing with waxes. Available in boxes of 20 or individually each measuring 229 x 152 x 10mm.
Abrasive Material Aluminium Oxide Silicon Carbide
Abrasive Type Mirlon
Abrasive Backing non-woven
Pack Quantity 1
Abrasive Grit 320
Web Attribute Set Sanding Pads & Sponges
EAN Barcode 6416868520132
