The Mirka vacuum adaptor is designed to connect the Mirka CEROS or Deco sander hose to a vacuum machine, but can be used for connecting many extraction hoses to a variety of power tools and other small machines. Made of rubber, it can be cut to length and has two vent outlets and five flexible vanes ensuring a good seal with your vacuum machine. With a total length of 200mm, the large opening is 60mm ID 65mm OD and the smaller end 25mm ID 30mm OD.
Web Attribute Set Filter Bags & Accessories
EAN Barcode 6416868949698
