ModelCraft 7 Piece Soft Grip No. 2 Craft Knife Set
- No. 2 handle with rubber soft grip, ncludes 6 different blades
- Magnetic pick-end for safe blade retrieval
- Durable aluminium collet secures blade
- Comes complete in a neat storage case
The ModelCraft No. 2 knife set includes the No. 2 handle featuring a soft comfort grip and magnetic end for picking up blades. In addition, there are 6 useful blades with differing profiles. The blades cover a wide variety of tasks, so it is easy to find which profile or profiles suit your work best.
The handle is 125mm long with a slightly textured rubber grip. The grip increases comfort and importantly increases control. The collet closing tube is brass; the small amount of extra weight improves the balance. The collet is machined aluminium for greater durability.
6 blades are included in the set:
#2 large fine point blade
#18 chisel blade
#19 angled chisel blade
#22 large curved blade
#24 deburring blade
#68 stencil edge blade
EAN Barcode | 5060252022477 |
- Standard Delivery* - £1.99
