Multi-Sharp Wetstone Water Cooled Chisel Plane Sharpener
117672
£24.16 £20.13
Low stock
- get it Tuesday 22nd Sep, order within and choose Premium delivery. Delivery info
  • Online exclusive
  • Drill powered for re-sharpening chisels / plane blades
  • Aluminium oxide grinding wheel for high quality results
  • Clamp firmly holds the blade at the selected angle
Customers Also Bought
Total: £45.80
WATER-COOLING is acknowledged by professionals to hone the finest edges. This compact system uses a controlled flow of water to eliminate over-heating of the blade edge and lose of temper in the steel. Simply fill the built-in reservoir with water, turn on the power drill and a continuous film of water covers the face of the grinding wheel.
WOOD CHISELS / PLANE BLADES
The system re-sharpens even badly damaged chisels / plane blades quickly, because it uses the relatively high power / torque of an electric drill. The clamp firmly holds the blade at the selected angle (25° to 40° ) for a precision ground edge. The traditional leather strop removes any burr, for a razor sharp edge.
SMALL TOOLS
The Tool Rest gives a firm base for re-sharpening, re-pointing and re-edging a whole range of small tools including: cold chisels, bradawls, screwdrivers, centre-punches, scribers, wood carving / turning tools, gouges etc. Marked angles on the rest indicates the tip angle.
Blade capacity 10-60mm wide.
Sharpening angles 25° , 30° , 35° , 40° for primary & secondary bevels, plus rebate chisels
Grinding wheel High quality aluminium oxide (replaceable)
Construction Very strong glass-reinforced nylon
Power source Any electric drill
  • Online exclusive
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
