Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 3-5 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Numatic NV750 Workshop Vacuum Extractor
  • Designed for the small, trade or home workshop or local workbench extraction
  • 1,200W "TwinFlo" vacuum motor & 35L capacity all steel drum
  • Three stage filtration of 0.5 microns @ 99.95%, HepaFlo bags included
  • Now also comes with an attached high mobility chassis
  • Included is a 2.5 metre x 51mm hose with a flexible rubber cuff
  • 51mm stainless steel "gulper" crevice clean up tool
  • Fits many bench top machines, made in the UK
  • Show More
£389.96 (£324.97 Ex. VAT)
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
Axminster 3 Year Guarantee
Perfect for almost any workshop and offering unrivalled performance, the NV 750 workshop vacuum extractor is quiet, efficient and built to last. Specifically aimed at users of small, bench top machines and power tools, this extractor is light in weight and easily moved on it's included wheeled chassis. The head assembly incorporates a 1,200W "TwinFlo" vacuum motor providing ample power for all tasks and has a 10 metre cord set. The extractor is fitted with a "Permatex" filter giving filtration down to 0.5 micron @ 99.95%, with the option of fitting a "HepaFlo" disposable filter bag if required for safe waste disposal - a must when machining MDF. As standard, this machine meets the L Class filtration standards but can be upgraded to M Class filtration standards with the addition of the optional HEPA module (210657). There is a blower socket for the exhaust air which can be directed away from the work area if required. The drum assembly incorporates a 51mm cyclonic inlet connector for large dust/chips, and a 51mm front entry for use with HepaFlo bags making this the perfect solution to almost all small machinery or power tool applications. The accessory kit includes a 2.5 metre 51mm flexible extraction hose with a rubber expanding cuff for linking to most small workshop machines with up to 58mm dust ports. A 51mm stainless steel "gulper" crevice tool is provided for general workshop cleaning. The extractor now also comes with an attached high mobility chassis, which enables easy movement around the workshop. The drum can be easily removed from the chassis by releasing one clip. The wide range of accessories available enable this extractor to be tailored to suit your needs.
A 2.9 metre 32mm hose and rubber step down adaptor for connecting to hand operated power tools or small, bench top machines are popular accessories, as is the floor cleaning kit. This machine is the ideal solution for those requiring something portable and also to handle a large range of extraction tasks. It is robustly built in heavy gauge epoxy painted steel, and it's designed and made in England!
Specification
Specification
Airflow Volume 2,500 litre/min
Corded or Cordless Corded
Filter Performance 99.95% >0.5 micron
Max Capacity Dry 35 litre
Model NV750
Motor Power 1,200 W
Nett Weight 11.2 kg
Overall L x W x H 450 mm diameter x 650 mm height
Rating Trade
Sound Pressure Level [Uncertainty K] 66 dB(A) [0.2 dB]
Suction 23.5 kPa
Plug Fitted UK 3 pin plug
Extractor Classification no value
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
