Numatic WV 370-2 Wet & Dry With AA12 Wet/Dry Kit
- Tough commercial wet or dry vacuum
- 1,060W Twinflo bypass motor
- Float valve automatic shut-off when full of liquid
- Optional Hepa filter bags for dry use
- Large capacity 15 litres dry/9 litres wet
- Castors and wheels provide excellent manoeuvrability
- Full wet and dry tool kit included
The Numatic WV 370-2 is a robust commercial wet or dry vacuum. Compact, versatile and manoeuvrable, this machine offers excellent value for money. The size of this machine makes it very portable and easy to work with yet still provides you with 15 litres dry or 9 litres wet capacity.
Changing between the 2 applications is quick and easy, and takes less than a minute. The wet float on the machine automatically shuts the machine down to prevent water from entering the motor once the tank is full. In dry use, optional Hepa-flo filter bags improve filtration and make waste disposal easier and cleaner.
The Numatic 1,060W Twinflo motor ensures constant high performance and a long trouble-free working life.
The WV 370-2 comes complete with the AA12 floor kit, comprising 32mm hand tube, 2 x 32mm extension tubes, 2.4m of Nuflex hose, a 300mm dry brush nozzle and a 300mm wet pickup nozzle.
Airflow Volume | 2,940 litre/min |
Cable Length | 10 m |
Corded or Cordless | Corded |
EAN Barcode | 5028965247006 |
Extractor Classification | no value |
Max Capacity Dry | 15 litre |
Max Capacity Wet | 9 litre |
Model | WV 370-2 |
Motor Power | 1,060 W |
Nett Weight | 7.1 kg |
Overall L x W x H | 360 mm x 370 mm x 510 mm |
Plug Fitted | 230V - UK BS89/13 13A Type G (2P+Earth) |
Rating | Trade/Professional |
Sound Pressure Level LpA [Uncertainty K] | 77 dB(A) [0.5 dB] |
Suction | 23.5 kPa |
Voltage | 230 V |
- Standard Delivery* - Free
